I changed my limit switches to industive (from magnetic) and ready to have them work.
I see them in Mach3 working fine.
A is slave to Y. If moving towards Y-- the limit triggers stop the gantry as normal. But when homing, the A and Y do wrong stuff.
X homes ok, comming off the limit.
But while Y remains in the right place after homing, A is moving backwards to bend the gantry.
I tried several solution including the oriuginal Ref All Home button config, and also the RefCombination (10) but no success.
I have the same configuration as Mikeee, with A slave to Y.
I tried to modify the Ref All Home button,and made the following:
DoButon (22) ' s ref for X, at least behaves like this
RefCombination( 10) ' this is supposed to home Y and A
but the behaviour is wrong again.... Y remains in position while A goes back and bends the gantry.
Do i do anythoing wrong here?
thanks
Marius
