587,019 active members*
4,094 visitors online*
Results 1 to 6 of 6
    Jun 2009
    32
    Micro steps info needed
    Hi
    How do I determine the setting for the micro steps of the driver.
    I am setting up a DIY CNC plasma table.
    I am using a stepper drivers PSD 6056-2p with a NEMA 23 495 oz stepper motor.
    Tom
    Jan 2010
    2141
    According to the manual at http://www.motionsolution.net/Downlo...PSD6056-2P.pdf you will need to set the DIP switches for the desired microstep value.
    Then you will have to configure your motion control software (such as Mach3) to handle the expected number of steps per inch, based on your driver's microstep setting as well as the details of the mechanical linkage between your motor(s) and the plasma cutter head location (for example, based on ball screw pitch, any possible gearing or belt drive, or rack and pinion geometry).
    Jan 2006
    2985
    I think you are asking which microstep setting YOU should use, not how to set it, correct?
    A higher number of steps per revolution will give you higher resolution so you will be able to make smaller movements on the machine.
    You do not want the steps setting to be too high or mach (assuming you are using mach3) will not be able to output pulses fast enough to get the max speed you need.
    It would help to know what sort of drive arrangement you have and how fast you want to be able to go. On a rack and pinion setup you might want a higher microstep setting than on a leadscrew drive machine.
    Matt
    Jun 2009
    32
    Thanks for the replys
    I am asking about the micro step dip switch setting. I am running a rack and pinion for the Y axis with a 10 tooth gear. the Z is a lead screw with 13 tpi with a slight gear increase from the motor to the screw (16 tooth screw and 17 tooth on the motor). The table is running well but I just wanted to know if I needed to change the micro steps for a better operation I think I am running about 400 to 800 steps.
    I am using Mach 3 and have setup the steps per for the 3 axis just trying to fine tune the table.
    Havef un
    Tom
    Jun 2009
    32
    I made a error in above post I am using a 20 tooth gear for the rack drive.
    Jan 2006
    2985
    Higher number of steps will give you a bit smoother operation and more resolution. If it is working fine, I'd leave it alone.
  1. Steps per unit mach3 cnc. Help needed
    By youngmasterpete in forum Mach Software (ArtSoft software)
    Last Post: 06-25-2012, 01:12 PM
  2. Linistepper 32nd or 64th micro steps?
    By Kingjamez in forum Open Source Controller Boards
    Last Post: 03-19-2008, 06:35 AM
  3. Micro-Swing info....
    By Dave Dahl in forum Uncategorised MetalWorking Machines
    Last Post: 03-01-2008, 02:37 PM
  4. Taig Micro Mill 2000 steps per unit
    By JV11 in forum Linear and Rotary Motion
    Last Post: 09-26-2006, 01:13 PM
  5. Full Steps -vs- Micro Steps
    By DJB282000 in forum CNC Machine Related Electronics
    Last Post: 12-29-2005, 06:25 AM
