586,410 active members*
3,322 visitors online*
Page 1 of 2 12
Results 1 to 20 of 21
    Jun 2010
    27
    Mach3 taking a short cut.
    Attachment 181019
    If the cutting speed is to high, Mach takes a short-cut. The rounded edges are supposed to be straight. It probably has to do with the general configuration (constant velocity) or with the available computer memory. It doesn't happen always. That is why I think that it can be a memory problem as-well, cutting large files. Can anybody give me a good advice to avoid this. I annexed a screen-shot of the general config.
    Thanks!Attachment 181020
    Jan 2006
    2985
    When is the rounding happening? When the cutter goes from one letter to the next? You can try turning off constant velocity and see if that helps. You could also put in a G4 dwell at a problem spot to see if that helps you out.
    Matt
    Jun 2010
    27
    It's a "Lace" strategy. It happens going in the Z direction.
    What does this G4 do and where in the G-code do I put this?
    Jan 2006
    2985
    It is a dwell as I said, you can google it for syntax.
    CV mode normally affects the path in tight corners. If you ask it to dwell in the corner, it would go to the corner, dwell, then resume with the Z move. The location in the code should be the line after the line which commands the bit to the "corner" of the toolpath.
    Matt
    Jun 2010
    27
    Thats not easy to do in a generated G-code, at leaste 5 Mb of lines. There must be a better solution in the adjustment of mach.
    Jan 2006
    2985
    I said you can try turning off CV mode. The G4 idea is for identifying the problem, not solving it!
    Nov 2008
    412
    Try "exact stop" setting.
    Forget about global warming...Visualize using your turn signal!
    Jun 2010
    27
    Can you explain why it doesn't happen always. In general with big files.
    Jun 2010
    27
    Result at half the speed!
    Jun 2007
    180
    What version of Mach3 are you running? There are some issues with CV in older versions. If your not running R3.043.066, try loading it. Also looking at your config, you are not using any CV distance tolerance. Try enabling that and play with the settings. I'm running very large files (over a million lines of code) and I do not use stop CV on angles, but I do use CV distance tolerance.
    Jun 2010
    27
    Sounds interesting! Have you got a screenshot of you general config?
    Jun 2010
    27
    I'm still running version R3.042.020 Lest hope that this upgrade will be the solution!
    Jun 2010
    27
    Quote Originally Posted by jeffery926 View Post
    Hello Jeffery, What do you use as distance tolerance? I updated now to the last version and want to do some tests.
    Jun 2007
    180
    I'm laser engraving 8bit shades with my machine. I set the CV distance tolerance at the largest move any of the axis's will go at one time. My setting is .0255, but your setting may be different based on the G-codes your running. Disable your spindle and just do some air cutting and play with the setting and see what works best.
    Jun 2010
    27
    I made it 1. now, but I'm working in mm. Less looks very safe, but slow. First I'll be trying this. Thanks!
    Jun 2007
    180
    Well, I kinda figured you was using MM, so the settings will be based on your machine, units and g-code. If it runs to slow, keep increasing that number until it runs like you need it.
    Jun 2010
    27
    What happens with the G2 G3 codes if you change this?
    Jun 2007
    180
    I do not have a clue on that one. Try it. I'm only engraving with my Mach3 machines.
    Jun 2010
    27
    Jun 2007
    180
    I'm curious. Have you resolved your problem and did upgrading to the latest version of Mach3 and the CV settings make a difference?
Page 1 of 2 12
  1. Taking the plunge again!!!
    By Ricardoco in forum Benchtop Machines
    Last Post: 08-10-2011, 12:37 AM
  2. Machine taking off too soon
    By TerraWombat in forum Waterjet General Topics
    Last Post: 02-24-2011, 07:50 PM
  3. how short is too short for necks?
    By qotsarock in forum Musical Instrument Design and Construction
    Last Post: 10-26-2010, 04:55 PM
  4. taking the plunge............
    By laytonk in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 10-14-2007, 06:34 AM
  5. Taking the plunge
    By BSims66173 in forum Open Source CNC Machine Designs
    Last Post: 03-21-2007, 06:13 PM
