Hi guys.
Maybe this is an easy fix.
A wile back I connected Peter's DigiSpeed to my Sieg (Cummins) 7x12 lathe.
I just got Arturo's Bi-directional, Mini Power Supply and Charge Pump boards because I didn't have any more available inputs on my HobbyCNC board.
The more I read, the more I thing I should run Step/Direction vers. PWM.
The Charge Pump is/was giving me fits (the relay is opening and closing really fast) so I disconnected it from the circuit. was set to Port 2 Pin 1
With the Bi-directional board connected to my second port (B800)
Enable for DigiSpeed - port 2 pin 16
PWM for DigiSpeed - port 2 pin 14
Mach3Turn Disable Spindle Relays box unchecked
Clockwise Output #1
CCW Output #1
checked Spindle Motor Output box
checked PWM Control
Enabled Output #1 port 2 pin 14
I am a lot confused as to what to do with the Enable for DigiSpeed
Enabled Enable1 port 2 pin 16
I tried both Active Low and High, all I get is a solid red LED on the DigiSpeed
Maybe it's my 2nd port? It's a SYBA (Model No. SB-PCI9715-2P) 2 parallel ports, I bought off Newegg a year ago. Or that long cable I'm using.
Thanks,
Bill
