I have been just the breakout board of my machine to a PMDX-126 from the little one that came in the longs motor kit.
But now that I have the new board installed I am running into random ghost e-stops!
With the old board I had the debounce set at 200 and it would run perfectly.
Now with the new board I still get bad e-stops when it is set at 3500! At this debouce the machine runs into the hard stops before my limit switches are triggered. This does not seem safe to me. What is the max debouce that should be used?
I only get the ghost e-stops when the inverter is on, but the spindle does not have to be running. I have a Chinese 2.2kw spindle with a Hitachi x200 inverter.
I bought a Hitachi EMI Filter, NF-CEH20, to get rid of the problem, but it has not helped, $130 down the drain!
It has gotten a little better since I ran a ground wire from the case of the computer to the ground in the eletronics box.
If I unhook everything except drivers from the breakout board and install a jumper in pin 10 (the e-stop pin) I still get some problem e-stops even though there no e-stop circuit or switch hooked up.
Here is the thread on my build that has be running a year without these problems until I made the upgrade of the board.
Anyone have any thoughts?
Case
Attachment 181246
New Board
Attachment 181247
Old Board
Attachment 181249
Inverter and EMI Filter
Attachment 181248
