587,470 active members*
2,948 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Dedicated CNC programmer in small/medium sized shop?
Hybrid View
    I'm trying to convince management that we would be better having one dedicated programmer than having 5 different setup guys designing programs and making changes constantly at the machine. We have 6 lathes, 2 milling centers, and a 5-axis. What advice can you give me of the benefits of what i described? The main ones i see is consistency and control.
    M.E.
    www.wheeler-ind.com
    May 2005
    3920
    I'm not sure this is the right forum, it is more of a management issue than anything. However posting in a programming section might grad more readers. Either way I can see a wild debate coming.
    Quote Originally Posted by kkarasch View Post
    This depends significantly on the type of shop you have and the work done there. I've have had some experience in an FDA regulated environment and as such modifications to programs would take an act of congress. On the flip side you have job shops where you have no alternative but to allow the guy at the machine significant programming access. Here is no simple answer.
    The machines don't mater, what you do with them does mater.
    Context is everything, doing what you describe could be a liability.
    Consistency can be very important. To much control can be dangerous leading to alienated and even bored people manning the machines. Control can be destructive to moral and may lead to the loss of talent. If your focus is control you are already off on the wrong foot.
  1. Replies: 0
    Last Post: 02-20-2013, 08:10 AM
  2. Help me pick a medium sized CNC mill please!
    By acannell in forum Uncategorised MetalWorking Machines
    Last Post: 02-09-2013, 12:54 AM
  3. WTB: Small medium or large sized CNC machine in Alberta
    By djnbig in forum Uncategorised MetalWorking Machines
    Last Post: 05-20-2008, 09:06 AM
  4. Moving a Medium sized mill
    By CoCoMedic in forum Uncategorised MetalWorking Machines
    Last Post: 10-07-2006, 06:52 AM
  5. Anyone have a mini cnc lathe or medium sized cnc lathe
    By nymachinist in forum Mini Lathe
    Last Post: 01-24-2006, 03:36 AM
