586,119 active members*
3,644 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > Spindle Center to Cross Slide Measurement.
    Dec 2009
    8
    I want to measure the distance from the cross slide table to the center line of the spindle bore on a lathe (hypothetical situation...any horizontal lathe say a TL-1 ). The more accurate the measurement, the better the results ....Using best machine shop practices, what would be the best way to get that distance without spending NASA type money to do it ? There must be a number of ways to skin this cat what would you do ?
    Turn any diam, measure it, let's say 1", with a heigth gage on the table, measure distance from table to top of 1" diam, substract .500, and you're done.
    Acurracy depends on the tools used and your measure skills.
    Mario
    Jun 2009
    135
    An edge finder in the spindle and a block (123) and pin gages will do it.
    Dec 2009
    8
    thanks for taking the time to answer. I've got a handle on in it now...
  1. 9X20 cross slide help
    By bearwen in forum Mini Lathe
    Last Post: 01-15-2010, 03:07 AM
  2. Metal for cross slide
    By arizonavideo in forum MetalWork Discussion
    Last Post: 11-25-2009, 11:37 PM
  3. cross slide
    By nantz in forum Benchtop Machines
    Last Post: 07-13-2006, 12:09 AM
  4. cross slide
    By nantz in forum DIY CNC Router Table Machines
  5. Cross Slide Lubrication
    By sp00k1e in forum Uncategorised MetalWorking Machines
    Last Post: 02-13-2004, 12:05 AM
