I am having a problem with MACH3 with the VISTA SCREEN SET and it is driving me crazy.
I have referenced all axis and they are correctly moving to the reference positions. The DRO's read 0.0000
My problem is that when I program a
n06 G73 x0 y0 z-0.4 q0.125 r0.1 f6
n07 x1
The machine will drill the first hole correctly but will not move to x=1.000 that that the command line calls for. The DRO Indexes but the X axis is not moving. I understand that the G73 command is modal and that the n07 line is telling the machine to move to x=1.00 and execute the M7e command which the ANSI standards say is amodal until another cG command id instituted.
I can Jog the X axis via the MPG. It works and the DRO only updates as I turn the MPG
If I MDI the command g0 x1.000
the machine will not move the X axis.but the DRO increments as if it was moving.
MY skill set is old world and I am 71 so my thinking is there is something wrong
with MACH in the settings.
