I have integrated Mitsubishi controls and have never run across that expression, unless it refers to the rear contact of a multi contact sw, why is the switch a Y function (output) switches are usually X (input)?
But in the case of a PLC it is normal to only input once, as the contact can be changed to NC or NO in the logic.
Do you have a better reference, manual no etc? I could look it up.
Would this be the 3 key switches for program/parameter/TO lock-out?
Al.
Albert E.
