I wonder if it is safe to set base freq to something lower? Has anyone reported damaging a spindle if it was "under powered" ?
No it won't run well at all, if you went lower, & you could do damage to the drive, It is not that normal for a manufacture to give a Base frequency that is lower than the Max frequency, normally all 3 setting are set the same at what ever the max frequency of the spindle
I'm wondering if when they mean base frequency, it is the minimum frequency for the slowest speed the spindle can run at, which makes more sense
Mactec54
Mactec54
I guess the only way to find out is test it with the setting on the plate and run it at 300 and see what the rpms are.
I am still a couple of month from putting the machine together. But I will definitely post my findings.
Normally when using a VFD with a 'standard' 3ph Induction motor, the base speed refers to what it would run on the name plate frequency, normally at 50hz or 60Hz.
And whether 2 or 4 pole etc.
The high RPM water cooled 2 pole 24krpm spindles are not designed or capable of running on 50 or 60hz due to the very low inductance of the motor winding and rotor.
Those that have ignored or overlooked the minimum setting have usually resulted in the burn out of their motor.
Al.
Albert E.
naspc
Some VFD Drives for you to look at, Hitachi Delta Commander Teco Yaskawa there are other good drives as well, don't buy a cheap one, as it won't last very well with your spindle
Mactec54
Mac tech
Thanks for the VFD recommendation.
I will check them out tonight.
I'm glad this post wasn't to old and abandoned.
The VFD in the start of this thread is a Lenze VFD Drive, this is a good VFD Drive
Mactec54
I was thinking of that one also. The guy who I bought the spindle from recommends them.
But I am having a hard time finding specs on it.
Looking at that plate, I wonder if they're telling you you can configure the spindle two different ways? Either as an 18,000 rpm spindle, or a 24,000 rpm spindle?
please don't say that! It took awhile even begin to understand this stuff!
Why would the spindle be limited to a minimum of 18,000 rpm?
I wonder if that 18000 for single phase and 24000 at 3 phase?
The figures that I have come across and from those that have had failures, the minimum RPM, particularly with the air cooled models is 100 to 120Hz, this relates to 6000rpm.
These motors are very low inductance and the inductive reactance below around 120Hz is very low, which makes the motor prone to overheating and burn out.
In spite of the ads that state 0-400Hz.
Al.
Albert E.
naspc
naspc will have to post the series # of what spindle he has, as they have many different models with the same starting series #
The C42/47-SB will run @ 18,000 RPM with a Minimum of 12,000 RPM
The C41/47-DB-2DB will run @24,000 RPM with a minimum of 12,000 RPM
Mactec54
6000 could be the minimum for the water cooled that I have ran across in ads.
When you look at the diameter, it is not hard to imagine how much inductive material there is for that potential rotor diameter.
Al.
Albert E.
You seemed so sure before when you said his minimum was 18000. Where did the 18000 minimum speed come from? His photo shows a spindle with a part number that starts with 4147, but I can't find the exact number on the Teknomotor site: http://www.cnczone.com/forums/spindl...ml#post1454878
