586,111 active members*
3,522 visitors online*
    Oct 2007
    123
    power supply voltage for motors
    I currently have KL34H2160 - 1810ozin & a KL34H2120 - 1200ozin, running on KL6520 - 65V, 20A power supply. By the equation V=32*I(mH)^0.5 (per Gecko data) I get 71.5V & 80V for the two motors respectively. Am I correct to assume that I could run both of those motors at 72V (KL7220) safely instead of at the 65V I have them at now?
    Thanks for any help.
    --Mike Calvino
    Feb 2010
    Depends on the drive. What drives are you using?
    Feb 2010
    Saw in another thread you have Gecko 203Vs. You can run the motors at 72V.
    Oct 2007
    123
    Thanks, yes - 203V's.
  1. Lowering Power supply Voltage?
    By tesart in forum CNC Machine Related Electronics
    Last Post: 12-12-2008, 02:43 PM
  2. Voltage regulator on a CNC power supply
    By boatlover in forum CNC Machine Related Electronics
    Last Post: 06-10-2008, 05:00 AM
  3. Bridgeport Power Supply - what voltage?
    By damae in forum Bridgeport / Hardinge Mills
    Last Post: 02-03-2006, 11:13 AM
  4. Power supply voltage too high
    By spoiledbrat in forum CNC Machine Related Electronics
    Last Post: 06-14-2005, 03:39 AM
  5. How do I limit voltage out of a power supply?
    By buscht in forum CNC Machine Related Electronics
    Last Post: 01-05-2005, 03:03 PM
