586,069 active members*
3,820 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > Torus Pro As A "Production" Machine
Page 73 of 73 2363717273
Results 1,441 to 1,459 of 1459
  1. #1441
    Feb 2006
    7063
    Re: Torus Pro As A "Production" Machine
    Quote Originally Posted by Steve303 View Post
    Can't wait to see it in action Ray, Is the PDB for the Pulsar identical to the Torus Pro version as well?
    Steve
    Much like the ATC, all of the important parts are shared. The whole "power head" assembly is the same, but the mounting bracket, spindle hub, drawbar socket and a few other parts are different, due to the different spindles, and differences in available space on the two machines.
    Regards,
    Ray L.
  2. #1442
    Jan 2016
    386
    Looking for early beta testers yet??
    steve
  3. #1443
    Feb 2006
    7063
    steve
    Really don't need testers for the Pulsar version, since all the "active" components are identical to the Torus Pro.
    Regards,
    Ray L.
  4. #1444
    Jan 2016
    386
    Thought that might be the case. Still looking forward to seeing them in action!
    Steve
  5. #1445
    Feb 2006
    7063
    Finally getting around to building a proper test fixture for testing the ATCs for both the Torus Pro and Pulsar. Here is the fixture I'll be building shortly. It mimics all the Torus Pro mounting points and spindle location on one side, and Pulsar on the other. So, I'll be able to test one of each concurrently.
Name:	ATC Test Fixture.jpg
    Regards,
    Ray L.
  6. #1446
    Jun 2004
    6618
    This is cool stuff, Ray.
    How much longer on the Pulsar PDB?
    Ball park is fine.
    Lee
  7. #1447
    Feb 2006
    7063
    Here is most of the ATC test fixture:
    Attachment 344170
    This fixture exactly replicates the key dimensions of the Torus Pro and Pulsar:
    Spindle location relative to front of column
    Spindle location relative to left side of head carriage (where transfer arm drive bracket attaches)
    Spindle location relative to left side of column (where carousel bracket attaches)
    Spindle location relative to top of column (where carousel "hanger" bracket attaches)
    This will allow me to do all development and burn-in testing on the fixture, rather than on the actual machines. I can even run both systems at once. All that's left to do is mill a couple of simple aluminum mounting adaptors that provide the actual mounting points for the ATC brackets themselves.
    Regards,
    Ray L.
  8. #1448
    Jan 2016
    386
    Quote Originally Posted by LeeWay View Post
    Ball park is fine.
    Bump
    Steve
  9. #1449
    Jan 2016
    386
    Ray, do you know if your ATC will work with PathPilot ? I am really looking forward to the ATC.
    Steve
  10. #1450
    Feb 2006
    7063
    Steve
    The ATC supports numerous interfaces - serial, USB, Ethernet (both sockets and http), and others - but I have no plans to provide a "driver" for PathPilot, without some serious motivation in that direction.
    Regards,
    Ray L.
  11. #1451
    Jun 2004
    6618
    Ray, have you thought about having the covers on these 3D printed?
    It might be a better option than vacuum forming. You could add the attachment features, cut out etc all in the model and not have to do much if any 2nd ops to them. Not only that, but you could pick and choose the material and color. Beef it up in some areas. Make it thinner in others.
    I now have two 3D printers. One is rather large. Fusion3 F400. A smaller Craftbot Plus as well.
    They both print our weekly part load in 2 to 3 days, so they have some down time.
    The big one has a build platform of 14" x 14:" x 12.6". I would be willing to work with you on it if the build volume is large enough. If not, two parts might be viable.
    These printers are not your Grannies 3D printers.
    The filament selection is amazing as well. Both of these printers will print almost anything. Except for PEEK that require's hotter than 300C. Peek also require's deep pockets.
    Lee
  12. #1452
    Feb 2006
    7063
    Lee,
    I'd be interested in talking to you about that. My impression is it would be much more expensive and the quality would likely not be as good, but I'm open to discussion. I'll PM you.
    Regards,
    Ray L.
  13. #1453
    Feb 2006
    7063
    Lee,
    I'm not sure the PM is working.... I've sent you two PMs, but neither has shown up in my "Sent Items" folder. Did you get either one?
    Regards,
    Ray L.
  14. #1454
    Jun 2004
    6618
    I did. I just sent a PM.
    Thanks, Ray.
    Lee
  15. #1455
    Jan 2016
    120
    Hi Ray,
    I was wondering how the PDB was coming along for the Pulsar? I appreciate you putting the time in to make it right.
    Micah
  16. #1456
    Jan 2016
    386
    Quote Originally Posted by burbingus View Post
    Hi Ray,
    Micah
    Have you considered making your own PDB? Not that hard using Brain's PDB cad file. You can make it in a weekend and it works great, so much better than the LDB.
    http://www.cnczone.com/forums/novakon/333750-cad.html
    Steve
  17. #1457
    Jan 2016
    120
    Hey Steve,
    I actually bought a preorder for the PDB when I bought my Pulsar. The diy PDB looks awesome, but I figured I'd wait since I'd already bought in on Ray's design. Plus the R8 tooling change looks pretty cool.
    Micah
  18. #1458
    Jan 2016
    386
    Hey Steve,
    Micah
    Did John give you a ship date for the PDB?
  19. #1459
    Jan 2016
    120
    No, he recommended me getting with Ray, and I'm waiting to hear back from him about the status.
    Micah
  1. Replies: 5
    Last Post: 01-12-2014, 07:07 PM
  2. Need advice Setting Up production: 4 to 8 sq ft of 39" long 1x1" AL Angle daily use
    By aluminumwelder in forum Material Machining Solutions
    Last Post: 09-27-2013, 08:21 AM
  3. First "real parts" made on the Torus Pro
    By AUSTINMACHINING in forum Novakon
    Last Post: 05-30-2013, 04:06 AM
  4. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  5. Thread Milling using "C" axis no "Y" on the machine
    By tejano4life72 in forum Mori Seiki lathes
    Last Post: 07-19-2010, 08:59 PM
