586,117 active members*
3,414 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > Torus Pro As A "Production" Machine
Page 27 of 73 17252627282937
Results 521 to 540 of 1459
  1. #521
    Jan 2012
    469
    I love HSMXpress. I wish HSMWorks was cheaper - the ability to use 3D adaptive clearing even on prismatic parts is awesome! Makes zeros like me feel like CAM heroes..
  2. #522
    Feb 2006
    7063
    Quote Originally Posted by rlockwood View Post
    First you're buying solidworks, now you're using adaptive clearing? Who knows, maybe some day you'll buy a carbide endmill
    I have plenty of carbide tools, but until now, there's been no reason to use them, because I could get the same MRR with a HSS tool that cost 1/3 as much, and was much harder to damage. Even now, I don't think they'll necessarily get the job done any faster on average - I'm limited more by rigidity and spindle power than by tooling. I expect I can go at least 50% faster (not in feed, but in radial engagement) with the HSS tools. I'll need to see how hard I can push it.
    Regards,
    Ray L.
  3. #523
    Feb 2006
    7063
    Here's a prototype of one of the "tool receivers" for the ATC. This is the gadget that holds the unused tools in the ATC. The tools are held by their shanks, so the shanks stay clean and dry. It's a mini collet system, with the collet spring-loaded. When complete, there will be a disc screwed to the top of the collet, which is pushed up by springs in three of the holes surrounding the collet. Pushing down on the disc (done by a very small, short-throw air cylinder) releases the tool.
    Thanks to HSMXpress, the three milled parts for this took less than 15 minutes to make, and only a bit more than half that was machining time - the rest was manual toolchanges, flipping each part over once, etc. Things go a lot faster when you can cut at 50-100 IPM! And I now know I can cut the machining time about in half with some simple changes!
    Attachment 221412 Attachment 221414 Attachment 221416
    The last few days was also my first chance to really make good use of the super-duper $50 Coroplast enclosure I put on the machine bad in December. It works wonderfully! Not a drop, or a chip, leaked out. The only coolant that got on the floor leaked out from a bad weld in one of the trays, where I had repaired some shipping damage. The enclosure is head and shoulders better than shower curtains!
    Regards,
    Ray L.
  4. #524
    May 2009
    327
    100ipm! Holy hell! Quite a step up from the normal 18ipm I do on my little 135!
    -Keith
  5. #525
    Mar 2011
    480
    I downloaded HSM advisor last week and ran chiip thinning with a 3 flute Zrn lakeshore carbide end mill. I ran HSM adaptive clearing ...
    ..375 end mill
    Doc .4 "
    Step over .048
    Rpm 6000
    Feed 100 Ipm. (110 suggested).
    Ran great.
    Carbide is definatley stiff for those deep cuts.
    Surface finish was incredible. They must be sharp too.
  6. #526
    May 2009
    327
    You have got to film one of these cuts. I am very intrigued! I have a part that is going to require a ton of metal removal and am dreading having to have to do it the "old fasioned way". I bought one of the modular insert TTS tools from Tormach hoping it will help with some of the deep cuts I have to do.
    -Keith
  7. #527
    Feb 2006
    7063
    Quote Originally Posted by keithmcelhinney View Post
    -Keith
    Yeah, I'll do a video sometime, though there's not a whole lot to see, what with the raging torrent of opaque blue coolant.
    The other thing I've been meaning to do for a while is a PDB video, showing how good the tool retention is. I keep seeing posts in other forums with people talking about how TTS is only good for light milling, and how easily the tools pulls out. Ironically, even the Tormach guys seem to have a lot of problems with pullout with the Tormach PDB. I've NEVER had pull-out with any of my motor-driven PDBs, and I wanted to do a video where I'd take a TTS holder with a 1/2" endmill in it, dip the shank into a cup of coolant, then install it in the spindle, tighten it with the PDB, and run some heavy roughing. I've never actually tried it, but I bet it would work just fine....
    Regards,
    Ray L.
  8. #528
    Feb 2006
    7063
    -Keith
    Full disclosure - the 100 IPM was in plastic (UHMW). I'm running 50 IPM in aluminum, with 0.55" axial engagement, 0.050" radial engagement, and a 2-flute HSS tool. At those engagements, I know it will go a lot faster, probably close to 100IPM. Or I could continue running at 50 IPM, and probably double either the radial or axial engagements. With carbide, I'm sure I could hit 200, albeit at a smaller radial engagement, due to limited spindle power and rigidity. And since I'm running 4900 RPM with the HSS, carbide still would not buy me much, if anything, in MRR.
    I have a batch of HSS 3-flutes, which I think are the ideal solution for this machine. They'll let me at least double my MRR, without the high cost of carbide.
    Regards,
    Ray L.
  9. #529
    Mar 2011
    480
    Nice ray
    You mind sharing where you found 3 flute HSS ?.
    Thanks.
    Matt.
  10. #530
    Feb 2006
    7063
    Quote Originally Posted by LAKESNAKE View Post
    Nice ray
    Thanks.
    Matt.
    Sure: High Speed Steel End Mills, Square End, Ball Nose End Mills, Coated End Mills , Roughers and Finishers, HSS End Mills and High Speed Steel End Mills from Discount-Tools.com, the Nation's leading online cutting tool supplier.
    Great company to deal with. Good tools, good prices, great selection, and really good service.
    Regards,
    Ray L.
  11. #531
    Jan 2012
    469
    I've gotten 3 flute HSS end mills from enco a few times. I don't think I've seen high helix, 3 flute HSS end mills though, that would be neat. I'll check discount-tools..
  12. #532
    Jun 2007
    3757
    Great mini collet holder in the receiver!!
    What plastic did you use?
    Many more tools in a given disk diameter, due to only needing to be same size as flange.
    Beats the hell out of trying to hold by the flanged part, or even needing consistent shapes of flange, like grooves, etc.
  13. #533
    Feb 2011
    605
    One of my standard cuts is with a 3 flute 1/2" carbide tool, about .75-.90" deep and .060" wide at 90 IPM, with the spindle running 6800 RPM. I think your machine is more rigid than mine and you may be able to run those same feeds (with less spindle speed) and just have a higher chip load. I increase the amount of stepover as the tools get smaller in diameter. On 1/4" tools I run 40% stepover, even with deep cuts and let it rip.
    PM-45 CNC conversion built/run/sold.
  14. #534
    Feb 2006
    7063
    Quote Originally Posted by neilw20 View Post
    Neil,
    That collet is basically a "placeholder" made of UHMW. WAY too slippery for this application, it's what I had on-hand.
    But, I decided while I really like the concept, the collets will be too difficult for me to fabricate. I've already designed a new, simpler mechanism, which is trivial to fabricate. Still fits easily within the same form factor. And, it's positive locking, not dependent on friction, so it's better overall. Might get one made later today. Right now, gotta jump in the toy car ('64 Jag E-Type roadster), and do my part for Global Warming by creating some Greenhouse gasses....
    Regards,
    Ray L.
  15. #535
    Jun 2007
    3757
    Is that a V12 etype? My mate has one.
    Bloody awful fuel pump. Carry a spare or a wet towel if it overheats.
  16. #536
    Feb 2006
    7063
    Neil,
    I couldn't afford to feed a V-12. Mine is one of the early 3.8L inline sixes - the most "sporting", and valuable, of E-types.
Name:	JagDesktop1 1280x766.jpg
    Regards,
    Ray L.
  17. #537
    Jan 2012
    469
    Not sure what year, but there's at least one E-Type that usually shows up at the Vintage races here in BC. Pretty spiffy "little" cars
    edit: looks like it's a '64 as well. I think I was helping with flagging at one of the corners, this exact race haha.
    http://jag2jag.com/video/rivers-edge...y-mission-bc-2
  18. #538
    Feb 2006
    7063
    Quote Originally Posted by TiagoSantos View Post
    River's Edge Raceway, Mission BC - Part 1 - THE JAGUAR SOCIAL NETWORK of OWNERS
    That guy is having too much fun.... :-)
    Regards,
    Ray L.
  19. #539
    Jun 2007
    3757
    hmm. Getting valuable.
    your one, -- couldn't find a 1964 here. $175,000
    1962 Jaguar E Type Series I
    The V12 one. $55,000
    1973 Jaguar E Type Series III
    They are getting too valuable to drive??
  20. #540
    Feb 2006
    7063
    There is some kind of freakish "bubble" going on very recently, and auction prices have gone completely insane. Some people are paying stupid money for rather ordinary cars. One early car sold a few months ago for about $280K, and the same car sold again about two months later for over $400K! It's insane! It won't last. "Normal" price for that car would've been in the low $100s. Personally, I believe there are a lot of people these days who simply have so much money, if they want something, they pay whatever they have to pay to get it. For them, the difference between $100K and $400K is literally pocket change. There's no other explanation for paying 3X what that car was worth. There were a lot of these cars built, and lots of them for sale all the time. You can have a complete rust-bucket restored to 100-point status for well under $200K, so why spend $400K+?? Mine, at least, is worth more than I have in it, even though I've put 40K miles on it over the last 11-12 years since it was restored.
    Regards,
    Ray L.
  1. Replies: 5
    Last Post: 01-12-2014, 07:07 PM
  2. Need advice Setting Up production: 4 to 8 sq ft of 39" long 1x1" AL Angle daily use
    By aluminumwelder in forum Material Machining Solutions
    Last Post: 09-27-2013, 08:21 AM
  3. First "real parts" made on the Torus Pro
    By AUSTINMACHINING in forum Novakon
    Last Post: 05-30-2013, 04:06 AM
  4. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  5. Thread Milling using "C" axis no "Y" on the machine
    By tejano4life72 in forum Mori Seiki lathes
    Last Post: 07-19-2010, 08:59 PM
