586,112 active members*
3,102 visitors online*
    Feb 2012
    25
    Powermax 85 Torch ID question
    Hi everyone,
    I'm just wondering if there is a PM85 owner with a 25' machine torch who would like to bring up the service screen on their machine and see what the machine reports for an installed torch? Mine shows T105M25 and I wonder if this is correct. The 65, 85 and 105 do all seem to have the same part number listed for that torch in the catalogue, so maybe it's correct.
    Marv
    Jan 2008
    2247
    The Powermax65, 85 and 105 all identify the different torches as soon as they are plugged in. The power supply makes air flow corrections for the different lengths (for better cut quality and consumable life) and also determines whether the system is to be fired from the CPC interface connector or the torch trigger switch. T105 is the name of the Duramax torch that can be used on the 65, the 85 and the 105.......M = Machine torch, if you had a hand torch installed there would be an "H". 25 indicates the lead length. Sounds like your machine is indicating the torch you have plugged in correctly.
    A better place to find answeres like this is the tech sevice toll free line (listed in your operators manual) that takes you right to our technicians!
    Best regards, Jim Colt
  1. New Powermax 85 w/machine torch questions?
    By xalky in forum Hypertherm Plasma
    Last Post: 06-03-2012, 04:31 PM
  2. Powermax 45 T45v Torch ?
    By rideright in forum Hypertherm Plasma
    Last Post: 01-30-2012, 03:33 PM
  3. Powermax 85 question regarding mach3+bob+relay+torch start
    By hayaome in forum Hypertherm Plasma
    Last Post: 10-20-2011, 04:27 AM
  4. T60 Torch on a Powermax 1250
    By Stout in forum Hypertherm Plasma
    Last Post: 08-04-2011, 10:26 PM
  5. CandCnc + Powermax 45 + Machine Torch =
    By brouser1 in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 06-09-2010, 10:27 PM
