586,069 active members*
3,619 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > unboxed Harbor Freight X2 mill X axis wheel won't turn
    Oct 2005
    8
    Unhappy unboxed Harbor Freight X2 mill X axis wheel won't turn
    Ok, so I just received my mill, i am so happy. I mounted the X wheel handle, but the handle is stuck, the wheel wont turn, and I unlatched it from the side, I was going to force it, but I dont want to break anything, i checked underneath the base and I am not seeing anything like a bold or anything that is blocking free movement. Has any else had this problem as well? What should I do? Y and Z are all working smooth.
    Oct 2006
    210
    Did you check your gib adjustment and make sure that the gib locking lever is not tight?
    Oct 2005
    8
    Thanks for answering, actually it's the Y axis. I even removed on the right side of the base, the locking lever and the gib set screws. nothing.
    Jun 2004
    6618
    I would suggest that you loosen the screw retaining plate right under the Y axis wheel. Two bolts I think. You may need to remove it completely to see what is going on.
    That was probably one of the last things assembled on this machine and it may actually either be binding there on the screw or may even have a light coat of rust holding the parts together. Could have a bit of sand in there too. Hard to say for sure, but that should give you a better idea of what is happening.
    Lee
  1. Harbor Freight Mill into x-y axis CNC
    By MPaulHolmes in forum Hobby Discussion
    Last Post: 06-12-2009, 02:46 AM
  2. Replies: 20
    Last Post: 05-27-2009, 04:29 AM
  3. Anybody use or see the new Harbor Freight KX3 CNC mill?
    By squale in forum Benchtop Machines
    Last Post: 09-28-2008, 08:36 PM
  4. Harbor Freight Mill
    By MrRage in forum Uncategorised MetalWorking Machines
    Last Post: 09-27-2005, 03:07 AM
  5. Harbor Freight mill
    By motomitch1 in forum Benchtop Machines
    Last Post: 08-10-2003, 02:12 PM
