Originally Posted by
3space
@CR: Yes, I am sure you are right. Do you have pics of your setup? Do you have a table under your mill, so the plastic curtain goes from the ceiling to that table, then when you remove the curtain, you just sweep off the surface?
Actually, my mill sits over a big plastic tub, with sheet metal floor. Chips sweep up nicely:
PIG® Utility Containment Tray - PAK919 | New Pig
You can't see it in the pic, but the tray angles way down at the back right corner for drainage. The rear of the enclosure is sheet metal. The front door is sliding 1/4 inch plex. Left and right sides are heavy shower liner. It WAS plexiglas, but the curtain can move if something long encounters it. None of it looks this clean and new anymore.
I suspect I will do exactly that. Would like to see pics though, if there is another thread where you have posted them.
BTW, it was you that converted the old bed frame to a bad-ass lathe stand, correct? (I read that about 4 months ago, so I might be remembering wrong)
Yes, that was me, although not a bedframe but 1 1/2 inch angle iron from some industrial shelving that I picked up cheap. That angle iron built both the lathe stand and the mill stand. Both were designed for flood cooling from the start.
Page 89
CR.
http://crevicereamer.com
Too many PMs. Email me to my name plus At A O L dot com.
