Some help With the Best Cuter For the Job in Mohogany
I mostly work with aluminum, so please bear with me. I don't normally do much wood work. Just some quick and dirty awards plaques for my fishing club, but...
I told a friend (he has helped me out before) I would take a shot at cutting his company logo out of a piece of mohogany he is bringing over. Its big enough to do what he wants atleast three times and the scrap is mine, so I get a minimum of three tries to get it decent. Its an old piece of wood that has been thickness plained, so I don't know how dry it is going to be. The rough work and the cut out can be done with .250, but the main body of the logo needs to be cut out with a .1875, and there is a secondary background feature that will look better with the smallest cutter I can use. I can get it roughly close all over with the .1875, but I am thinking I am going to need to finish with .125 or smaller to cut one the profiles to "look" square on the inside corners. I know. I know. Finish it with a hammer and chisel, but then I'll have to make a chisel. I don't have one that small.
I figured I would just use the numbers from G-Wizard for speed and feed, but I am wondering which cutter is going to give me the best over all cut with the least amount of tearing.
My CNC router currently has a fixed speed head on it, but I do have a variable speed head I've been meaning to make a mount for on one of the mills if lower speeds are going to really make the difference on this cut. Currently its turning about 34000 RPM and I have it capped at 300IPM for rapids. I don't hesitate to cut MDF at feeds upto 225 IPM but it always needs some cleanup.
My main questions is what cutter geometry is going to give the best over all finish for this piece of mohogany?
Bob La Londe
http://www.YumaBassMan.com
