586,477 active members*
2,437 visitors online*
    Jul 2007
    excitech with syntec controller
    can any one let me me know how to set X0 , Y0 & Z0 after homing the machine . i am new user so if some one can give me step by step process to start the machine
    hi,which point is work origin ? left up,left down,right up or right down ?
    how big is the work ? and how big is the material size? please make sure the material is big and thick enough for the work.
    and please make sure the tool is suitable for the material.
    usually the work origin is in the left down coner,you can press X+, OR X- , Y+ or Y- to move the spindle to the material,then press Z- and move the tool touch the material surface,please let the spindle come down slowly,because if it comes too fast ,you may break the tool. after that press X Y-0,Z-0 and press Start.
    before processing,i suggest you to make a simulation first to find if there is anything with the working file.
    good luck for you .
  1. Excitech CNC - Syntec Controller Users
    By BC-CNC in forum Chinese Machines
    Last Post: 01-11-2020, 10:38 AM
  2. Syntec Controller and Network Access
    By nash in forum Chinese Machines
    Last Post: 11-14-2019, 10:35 AM
  3. Syntec EZ4 mill controller manual
    By Harikarwa in forum Chinese Machines
    Last Post: 03-20-2013, 08:47 AM
  4. Who has syntec controller running there chinese atc
    By simso in forum Chinese Machines
    Last Post: 10-22-2011, 02:47 PM
