586,089 active members*
3,893 visitors online*
    Mar 2008
    454
    Toolpaths for 2x parts / assembly?
    I have stock big enough to cut out 2 different parts.
    The 2 parts were designed independently with SW and are in 2 different files.
    I would like to create 1 toolpath/gcode file to cut out both parts from this single piece of stock... but now sure how to do it.
    How do I go about importing 2 parts into a single solidcam project to create toolpaths?
    Do I need to copy both parts into a single SW file first?
    Can I open an assembly in solidcam?
    V
    Oct 2012
    60
    Quote Originally Posted by viroy View Post
    V
    Viroy, you should be able to put the two parts into a higher level assembly and then start a machining project from that higher level assembly. This implies that indeed solidcam can open assemblies. In fact, the solidcam file itself has both part and assembly modes.
    Mar 2008
    454
    ok I created an assembly of the two parts separated by the tool width and on the same plane.
    When I load them into solidcam, it will not let me pick an origin, it will not let me define the stock, and it will not let me choose the proper upper & lower levels.
    I want the home coordinate to be directly in the middle (between) the two parts, so i choose 'define' and select a point at one end, then delta 1/2 the width... it does put the origin in the correct spot and XYZ directions are correct... but the green check is greyed out.
    Once again when I try to define the stock, I select both parts which creates a box around them as expected... but the green check is greyed out.
    What is going on here? Why will it not allow me to do this?
    Mar 2008
    454
    Think I have the solution.... but requires inconvenient workaround.
    When I create an assembly in SW, the first part I insert gets 'fixed' and cannot be moved even though it is always off center from the origin.
    So instead I add two of that first part and then delete the first 'fixed' one... I can then move the part to the correct position relative to the origin.
    I then set the XYZ directions of the origin with 'reference geometry -> coordinate system'.
    Then I add the second part and mate as needed. One final check of position relative to origin and then save.
    Now if I open in solidcam, I can choose that origin created in the SW assembly as the origin instead of trying to define a new one
    I can also define stock around both parts and set upper/lower levels properly.
    Working on the toolpath operations right now.
  1. CREATING NEW PARTS IN ASSEMBLY
    By camunderdog in forum Solidworks
    Last Post: 04-13-2013, 09:59 PM
  2. CREATING NEW PARTS IN ASSEMBLY
    Last Post: 04-08-2013, 08:20 PM
  3. spindle assembly/parts drawing for a SV-50?
    By tc429 in forum Mori Seiki Mills
    Last Post: 02-09-2011, 07:09 PM
  4. Creating cavity from assembly parts?
    By Rich05 in forum Solidworks
    Last Post: 07-24-2008, 01:01 AM
  5. Trimming parts in assembly
    By Capgama in forum Solidworks
    Last Post: 09-19-2006, 03:49 PM
