Newbe here....I just got my first CNC milling machine. A Prototrak Plus.... I have no idea how to program this machine. Does anyone have a operators, programers manual ? I tried the manufacturer and was told it was out of print.
JOHN
JOHN
Did you find a manual yet? I look to see if I still have one.
Bill K
Any luck on the manual? I also have a prototrak plus and could use a programming manual.
Simracn,
I'm sure I could find a manual, scan it and send it to you..... BUT where are YOU. Nothing in you profile for location.
Not in USA....... = NOT getting copy of manual.
Try Amazon or ebay. they have them.
Bill K
Hello Bill, am down in the middle of Fl. But have been dealing with SWI on making sure my Y axis fault is the servo amp module. So far everything is pointing towards that. And sounds like the plus may not be supported much longer... sigh. But did find out that the newer X axis brg housing with a bit of a mod to the bearing race and taking off matl on the mach side, it works great :-)
The Guy in Tech have been working with found one and sent me a PDF of it, so I was able to acquire a copy, thank you though for checking! And now if someone else needs a copy, may be able to work a help out.
Thank you again! much appreciated even if you didn't have to send one :-)
Here is a link to the ProtoTRAK Plus Manual.
https://www.dropbox.com/s/2evbiq0igi...0Plus.pdf?dl=0
Here is a link to a ProtoTRAK Plus folder with other manuals and some programming sheets to use.
https://www.dropbox.com/sh/26r0c8fth...2977YO02a?dl=0
