586,108 active members*
3,208 visitors online*
    Sep 2009
    38
    CHIP THICKNESS
    Is there a general rule for chip thickness (feed per tooth) when trochoidal milling. The only information I found was to increase it 3.5 times over conventional milling.
    Mar 2006
    2712
    Usually the cutter/insert manufacturers have that info in their online catalog tech sections. I know Sandvik and Ingersol do a good job of it.
    Dick Z
    DZASTR
  1. how to add a wall thickness
    By yllis in forum Rhino 3D
    Last Post: 02-14-2012, 08:53 AM
  2. Chip to Chip Time
    By Gene0552 in forum MetalWork Discussion
    Last Post: 09-01-2010, 05:05 PM
  3. Pines Numbers 3&4 Benders Frame Thickness and Nose Thickness
    By morribi in forum Bending, Forging, Extrusion...
    Last Post: 02-04-2010, 04:59 AM
  4. Amperage vs. Thickness
    By johntm in forum Waterjet General Topics
    Last Post: 09-21-2008, 05:32 PM
