Hi everyone and I am going to start with a apology I am always willing to learn but there is only so much you can learn by reading.
I have bought a milling machine emco that a guy has started to convert but has given up so I jumped on it as it was very cheap.
Now I stripped the machine and replacing the old ball screw with anti backlash type and moving the z axis motor as this was not placed in the right place.
This I am ok with this the problem comes with the electrics involved
Now I have purchessed the following
1 nema 34
2. Nema 24
3 ma860h drivers
1 36v 11 amp power supply
1 c11g bob
Now I hope these drivers are ok I have done the calculations on the motors and got ones with he right nm/in.
Now my first problem comes with power.
Now the combined amp for the motors is 11.2amps max now I no they will only use 75% so I believe that side is ok but the voltage for the motors combined is 11.3 volts but I have 36volts. Do I need to look for a different power supply.with less power?
Also I have had a issue that I tryied to run before I could walk and think I have screwed up some how because after test wiring the motors on the table one driver has a red light on as soon as you turn it on I guess I have screwd that driver and will need to buy a replacement. Unsure how as the wiring seemed to be correct.
Sorry for the hand full of question but I am new here and just want to learn and get this right as wife is going to kill me if I keep spending money on it.
I will post some pics of the machine how I picked it up and thanks for help in advance.this was per strip and throw away far to small motors.
Attachment 182307Attachment 182308Attachment 182309
