I need to square my head to a table on Y axis as it is nodding and loosing 0.004" over 12" of Y travel. I hear that it is done with shimming where the column is bolted to a base. I identified such places but I am not certain on;
1. Shimming material. What can I use and what size. Can I use filler gauge?
2. SIze of the shim. Right now the column is flush bolted to a base. Once I place shims on one side (to eliminate column noding) it will effectively rest on a small shim and not have a full contact to a base. Will it not drastically undermine rigidity of a column?
thx
