I purchased IGAk's NM 200 V2 and decided to extend the front tray / door assembly by three inches to be able to take advantage of Novakons 16 inch Y axis movement.
Hear are a few pictures of the project.
First is the1/8 by 1.5 inch flat steel I used to move the front tray. The notch is to clear the factory welds of the support bars
ID:	182323 Click image for larger version.
ID:	182324 Click image for larger version.
ID:	182338 Click image for larger version.
ID:	182331 Click image for larger version.
Here are the left and right side panels that run from the pan angle supports to the extended front assembly. Note the notch cut in the pan support bracket to allow full 16 inch travel.
ID:	182325 Click image for larger version.
ID:	182327 Click image for larger version.
Pictures of the filler panels to keep the coolant from getting on my shop floor and shoes.
ID:	182328 Click image for larger version.
ID:	182329 Click image for larger version.
The completed project and the machine with my rendition of IGAK'S enclosure built and installed.
ID:	182333 Click image for larger version.
ID:	182334 Click image for larger version.
Now all I have to do is learn cad, cam, Mach 3 and Corel draw and I will be good to go,
Oh and how to turn it on lol
