Large format printer.....wax maybe?
Hi Guy's,
It's a rare thing me venturing this far down the forum pages....I generaly hide out in the DIY router area.
Anyhow, I'm very interested in your experiences/ideas surrounding the idea of either adapting my current machine or a stand alone machine for 3d printing parts typically 2200 x 400 x 200.
printing media would ideally be blue machinable wax as I have a ton of it.....yes literaly 1000kg, some $15000 AUS. It has a softening temp around 8o deg celcius and a reccomended recycling temp to pour of around 140 deg. celcius.
I see there has been a little movement with using 3d printing with concrete on a very large scale in constuction so I guess I'm not completly mad.
I imagine i'll need to print onto a heated platten ( if I print using a heated product such as wax), experiment with nozzle temps of 100-125 deg. celcius.
if I use my slow router I'll probably use a nozzel diameter of 5mm to create rough stock and remachine with the router after the wax has cooled, however if I were to build a quick "traditional" printer with belt drive etc. I could go for a small nozzle and have a product that has a much better finish to begin with.
I'm producing one off model ship moulds for fibreglassing, sometimes it's the plug to take the mould from......depends on the hull shape.
Software
What is currently the preferred cheap/opensource software at the moment?
Would ReplicatorG be your recommendation?
Heated Nozzle and drive options
Do you have any ideas on how to feed a pelletized wax into the heated nozzle?
I would love to hear(read) your suggestions!
Cheers Liam
http://www.cnczone.com/forums/cnc_wood_router_project_log/101936-5_axis_build_full_steam.html
