586,036 active members*
4,018 visitors online*
Thread: Toolsetter
Results 1 to 12 of 12
    Oct 2011
    477
    Toolsetter
    Okay, can someone who has a Tormach Toolsetter educate me on how it works and what if any alternatives there are out there that will work with the ATC automatic tool setup routine.
    Sounds like a good way to go but at $800+ I would like to have a warm fuzzy feeling about it.
    nitewatchman
    Mar 2009
    199
    I just use a height gauge on a surface plate with the TSS height gauge ring.
    Feb 2006
    7063
    I use the Tormach height gauge and their little surface plate. It takes me maybe 60 seconds to measure the lengths for all the tools in a typical job, and enter them into the tool table. Can't imagine automating that process to be worthwhile.
    Regards,
    Ray L.
    Nov 2010
    360
    ~$100 for a Wildhorse probe, and set it up in its toolsetter configuration.
    Quote Originally Posted by howecnc View Post
    Same here.
    Don Clement
    Oct 2006
    137
    I have one and reckon it is cool how it just does it all. All you do is load the ATC with the tool numbers and tell it to touch off.
    Up to you whether you want to spend the money.
    The only thing I can't touch off is the Haimer, due to the spring in the Haimer being weaker that the toolsetter, the way I get around it (have posted this before)
    is what I call the surrogate Haimer, where you measure the Haimer length at ZERO, record it and then using a setscrew toolholder(because they are the cheapest)
    make the surrogate- which is a piece of bar with a step on it,so it can't push into the setscrew toolholder, And you machine it to the same length as the Haimer is at ZERO.
    So all you do to use it is to use the surrogate to touch off then swap it and use the Haimer to set ZERO.
    Will
    Sep 2012
    1543
    I love the toolsetter. I wouldn't have an ATC without it. Push of a button and you can watch it measure 10 tools, I could get a video of it tomorrow if you like?
    Oct 2011
    477
    Quote Originally Posted by BAMCNC.COM View Post
    Please if it is not too much trouble.
    nitewatchman
    Sep 2012
    1543
    No problem, I may actually have a video showing it in use already.
    Sep 2012
    1543
    PM Sent
    Oct 2011
    477
    Tried to reply but I think you are full.
    Sep 2012
    1543
    Weird. Tormach-ETS on YouTube should get you something
  1. Toolsetter Adjustment
    By JHECNC in forum Daewoo/Doosan
    Last Post: 03-18-2009, 12:54 AM
  2. Where NOT to put your toolsetter.
    By behindpropeller in forum Haas Mills
    Last Post: 02-22-2009, 02:11 AM
  3. Help with Gcode for toolsetter
    By Harryman in forum WinCnc
    Last Post: 01-10-2009, 06:00 PM
  4. Toolsetter problems
    By inertialabs in forum Haas Mills
    Last Post: 10-23-2008, 08:51 PM
  5. Probe and toolsetter suggestions?
    By REVCAM_Bob in forum Uncategorised MetalWorking Machines
    Last Post: 01-01-2008, 01:12 AM
