587,040 active members*
2,857 visitors online*
    May 2004
    402
    Slot addressing in Meldas controllers
    I am looking to move a set of cards from a FCA320HLX-V. controller (6 slot) cage into a FCA330HLX-V (10 slot). How do the I/O cards addresses get allocated? If a card is placed in a particular slot does that define address range of it's digital i/o or is it inherent to the jumper settings on the card?
    Andrew Mawson
    East Sussex, UK
    May 2004
    402
    well in the absence of any response I tried it anyway! Certainly digital inputs turn up on the PLC interface check screen in the same place using my trusty test lead and switch to +24V !. I assume the digital outputs will also follow suite but I don't know how to directly set an output bit to test them.
    If anyone can tell me how to directly set an output bit I would be grateful. I understand using the force output facility only writes to memory and the plc actually sets the outputs but can you tell me differently????????
    Andrew Mawson
    East Sussex, UK
    Oct 2007
    179
    Hi Andrew I have a Beaver partsmaster with Heidenhain 355 and I use Featurecam. Could you possibly email me the post processor you have it would be a big help!
    [email protected]
    Thanks John.
    May 2004
    402
    In case anyone else stumbles across this thread looking for the same information in future, I attach a copy of the address mapping for the FCA320HLX-V & FCA330HLX-V controllers
    Attached Thumbnails Attached Thumbnails image2013-05-07-142024.pdf
    Andrew Mawson
    East Sussex, UK
  1. Replies: 1
    Last Post: 01-04-2013, 04:45 AM
  2. EZ Trak Internal addressing error
    By Zeke13 in forum Bridgeport / Hardinge Mills
    Last Post: 05-20-2009, 12:55 AM
  3. Meldas 64 control card slot ??
    By ajm100a in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-27-2008, 10:17 AM
  4. Internal Addressing Error
    By BobL in forum Bridgeport / Hardinge Mills
    Last Post: 06-06-2005, 11:11 PM
  5. Internal addressing error
    By BobL in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-26-2005, 05:55 PM
