586,410 active members*
3,254 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > TS3040C-H80 Mach3Mill.xml file setup correctly with swapped X and Y axis
    Jun 2011
    24
    Hi
    I have finally sorted this machine and have it setup correctly after a lot of available manuals for the same machine with different settings.
    I have swapped the default X and Y axis around for what I consider to be a better working area and better suited to most cad/cam software.
    After downloading file, if you want to then rename it or leave as it is and put it into C:\Mach3 folder. REMEMBER to open mach3 then choose this file rather than the standard mach3mill.xml file
    Here is the XandYswappedMach3Mil.xml file......
    Attached Files Attached Files
    Jun 2011
    24
    ADMIN - could you make this sticky please as it will be very useful for others that like me found 4 user manuals online, all exactly the same except the settings are different
    Jun 2011
    24
    by the way if you'd rather keep the X and Y axis as default that came with the machine i.e. X short side Y long side then just use this file but swap the 16 and the 4 around and the 5 and 17 around in config, ports and pins, motor outputs, but to me the config I setup makes more sense.
    Dec 2011
    I also swapted x to be a long side. Just didn't make sense the other way around. Also reattached the home switch to the other end of new X axis.
    Apr 2014
    4
    Re: TS3040C-H80 Mach3Mill.xml file setup correctly with swapped X and Y axis
    Do all new TS3040C machines have this issue and have to be corrected?
    Also is the TS3040C better than a 3040T? I see the TS3040C has a cable driven spindle, is this as strong (capable) as the direct drive spindle on the 3040T?
    Keen to buy one, just need some advice in plain old english lol
  1. Tonsen TS3040C-H80 - replace spindle directly on Z axis?
    By bearer in forum Chinese Machines
    Last Post: 04-28-2013, 10:21 AM
  2. 4 axis screen set not displaying correctly
    By robe_uk in forum Mach Software (ArtSoft software)
    Last Post: 08-22-2012, 11:23 PM
  3. G540: How do I load the mach3mill.xml file into Mach3?
    By deemon328 in forum Automation Technology Products
    Last Post: 09-01-2010, 01:31 AM
  4. 4th axis positioning is not posting correctly.
    By TXFred in forum Mastercam
    Last Post: 06-10-2010, 02:06 PM
  5. Z Axis is not working correctly.
    By Rich05 in forum Charter Oak Automation Support Forum
    Last Post: 09-22-2008, 03:29 PM
