586,036 active members*
3,517 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fagor Automation > X axis stalls during program, a light push on the table gets it going.(8025)
    May 2005
    39
    Not exactly a Fagor specific problem, but this forum seems most appropriate.
    The machine is a CMS (Upgrade Technologies) GT-27 lathe. The stall happens at the end of a G1 in the -X direction. During a stall the display shows the move is completed (Distance to go= 0.000), but also shows 'In Execution'.
    If I push on the table in the -X direction with a couple pounds of force the program will continue. If I 'pull' on the table in the +X direction while running (again, just a couple pounds force) it will usually stall. Another push in the -X direction and the program will continue.
    Any GT-27 owners had this problem? Probably the servo or encoder?
    QB
    Dec 2011
    73
    Quote Originally Posted by mp- View Post
    QB
    TO me this sounds like a mechanical issue (possibly motor torque is not enough) or maybe there is a following error on the x axis but is still within alarm limits
    24221
    I don't see it being encoder
    motor or drive are the possible candidates, can you swap the drive from the other axis, if same model?
    Try removing the motor mechanically, leave electrically connected and attempt a load on the shaft and see if it stalls easily?
    Al.
    Albert E.
  1. Start push buttons Biesse Rover 13 does`nt light
    By Christiaan in forum CNC Machining Centers
    Last Post: 11-23-2021, 09:52 PM
  2. 8025 and infinate program with DNC?
    By Jerry Shorter in forum Fagor Automation
    Last Post: 03-25-2017, 08:29 AM
  3. Send/receive program without output/input push
    By padobranac in forum Fanuc
    Last Post: 10-20-2010, 03:53 PM
  4. program stalls on M10
    By firekoe in forum Fanuc
    Last Post: 04-16-2010, 03:28 PM
  5. Fagor 8025 PLC-Intergated....Anyone know how to program
    By kmcwhq in forum Fagor Automation
    Last Post: 12-11-2009, 08:51 PM
