587,004 active members*
2,768 visitors online*
    Nov 2011
    Need help with Mach 3
    When I opened The Mach 3 program and the Session Program box comes up, I somehow hit the delete instead of OK, and now its not working. Can anyone tell me how to get it back? I tried restore and it didn't work. Thanks for any help.
    ARamey
    Apr 2003
    550
    In the folder where Mach exists there should be a subfolderr called xmlbackups. Open that folder and you will find a bunch of files and a readme file. Following the nstructions rename the backup of the xml you were using and your profile should come back....
    You can right click on the Mach icon and chose properties to help you locate things..
    Garry
  1. little lost on G03 between Mach and PCNC 1100 Mach...
    By Spinnetti in forum Tormach Personal CNC Mill
    Last Post: 10-30-2012, 02:56 PM
  2. Replies: 3
    Last Post: 05-14-2010, 09:16 AM
  3. Servo Drive Card for Mach II / Mach III
    By umarcnc in forum Mach Mill
    Last Post: 02-21-2010, 09:37 AM
  4. Confused: Mach Turn, Mach Mill, Mach 2/3 ?
    By CanSir in forum Mach Software (ArtSoft software)
    Last Post: 02-16-2007, 11:41 AM
  5. Moving to mach 3 need exact mach 2 screen
    By carlnpa in forum Mach Software (ArtSoft software)
    Last Post: 12-11-2005, 10:00 PM
