Hello everybody!
I'm a LinuxCNC user and I'm really happy with the way it behaves. I build camshafts for spare parts here in my country and I would like to know if there's an easy way to do the following:
What you see is a representation of a camshaft lobe and a cutter, let's say a mill, or a grinding wheel. I'm not an expert in using CAM software other than for turning operations, and I've never seen examples like this one.
What I would like to do, is to generate the profile for machining the lobe using a mill for example, but using only the movement of the rotary axis and the linear axis. So, camworks would be generating the G-CODE compensating the tool radius to mantain the tangential contact point all around the profile.
So, to sum up. I'm trying to use a Camworks, to test in LinuxCNC the possibility of generating a toolpath for a camshaft lobe that uses only one linear axis and one rotary axis, the tool is circular so this is doable compensating the radius, there's no need of a second linear axis for height compensation.
Do you think this is easy to do? I would love to test it, so I can rough my lobes with a mill in a machine that I can adapt by myself.
Thanks in advance for your help, and I hope I've been clear about my doubt.
Best regards.
Leonardo.
