586,096 active members*
3,762 visitors online*
IndustryArena Forum > CAM Software > Mastercam > SPEEDS AND FEEDS WILL NOTTRANSFER FROM TOOL
Results 1 to 12 of 12
    Mar 2013
    32
    I know it is a dumb question but I seemed to have messed with some config setting for my tools. I used to be able to click on a tool from my tool list and the speeds and feeds populated automatically, now, I have to re-type in the fields everytime, ? very frustrating. any clue what it might be ? thanks
    Dec 2008
    3109
    Previous post may help... link
    Have you actually set speed & feeds on the tool..... not in the operation ?
    - re-selecting the tool again should update all the fields in the operation....unless it has been "locked out", refer to the link for unchecking the "lock feeds / speeds"
    Mar 2013
    32
    yes, I defined the tool originally and made a mistake on the spindle speed , I then clicked edit tool went back into the parameters of the tool, made the change and re-selected the tool on the list but the SS field did not show the update, I then just typed it in the field again and rolled with it but I know I must have a done something wrong because I have never had this happen before. thanks, I will try anything you can think of, where is "LOCK SPEEDS AND FEEDS" located?
    Dec 2008
    3109
    Hit the word... link
    Mar 2013
    32
    tried the link idea superman and made sure the box was checked ---"USE TOLLS STEP PECK" still not updating..........? frutrating
    Jul 2003
    263
    select another tool for that operation and then reselect the original tool. that should take care of the problem.
    If you can ENVISION it I can make it
    Mar 2013
    32
    I tried that cncking, and still the spindle speed does not change...........?
    Mar 2013
    32
    there is a option when I right-click to re-initialize speeds and feeds and that works but that is more mouse clicks than should be.....
    Dec 2008
    3109
    Quote Originally Posted by cncbeastmaster View Post
    You did both areas ??
    .... Machine Group Properties and in the Config file .......
    I think the one in the config file is new in X5...and is missed by a lot of PPL
    Mar 2013
    32
    we are running X6 and I am not seeing anything in the config area or in the control def. ?
    Dec 2008
    3109
    There is one in the system config file, under the "Toolpaths" tab
    It is the last check item called "Lock Feedrates" --- must be ticked to be able to auto-update speeds & feeds in your ops
    Mar 2013
    32
    found it !! thank you
  1. Feeds & Speeds
    By weihmue in forum MetalWork Discussion
    Last Post: 02-06-2012, 02:56 AM
  2. Speeds & feeds
    By nateman_doo in forum Benchtop Machines
    Last Post: 11-21-2011, 02:54 PM
  3. Replies: 13
    Last Post: 01-26-2009, 04:52 PM
  4. Feeds and Speeds
    By sjotime! in forum Mach Software (ArtSoft software)
    Last Post: 02-17-2008, 10:46 PM
  5. feeds and speeds
    By Mortek in forum Hard / High Speed Machining
    Last Post: 02-28-2004, 10:59 AM
