Is there a system/product/method to lock a z-axis in place when power is turned off?
I am building a special purpose 10-foot by 6-foot CNC table that uses rack & pinion on the z-axis (probably should have used a screw method for z-axis, but already built for now). Just connected the wires to my z-axis stepper motor, and the it works fine. It raises and lowers the heavy z-axis perfectly. But when I turn the power off (shutting down for the day, or if electric power is lost), the z-axis falls down hard (to be expected since it is heavy). I didn't think about this when designing the table (oh well ... that's learning the hard way). Now I need to research how to fabricate something to hold the z-axis in place with power is off. Has anyone experience this problem? How did you solve it? Or do you have any suggestions?
Thanks in advance for your help.
Mike Falkner
