Milling external Radius
Hi Guys
I have a round bar of ~42mm mounted vertically and I need to create a 6mm radius around the corner. I would be using a ball-nose cutter of 8mm diameter.
I can set this up manually with a lot of circular cuts at varying depths. But it's a lot of work.
I can set this up with exporting a surface from Rhino, but the cut results aren't as smooth as it's a faceted surface.
Is there a more automated way I can do it? No big problem if there isn't, but it'd be great if there was.
Cheers
Dougal
I have lost count of the CAMBAM cuts I have run over the years. It's been phenomenal. But I keep finding new ways to challenge myself and my tools.
My X2 CNC Brain Build: http://www.cnczone.com/forums/showthread.php?t=61345
Gecko G250 wiring errors: http://www.cnczone.com/forums/showthread.php?t=68960
