586,116 active members*
3,387 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Inhibit Origin of Absolute position
    Oct 2007
    11
    We have a few VTL's with 0i controls and a few with 15b controls. On the 0i's you can't origin the absolute position's, but on the 15's you can. I've looked but can't find a parameter to turn this function off, does anyone know if this is possible?
    We had a machinist accidently origin the absolute position on the program check screen which caused a crash, I'm trying to prevent a recurrence.
    Dave
    Oct 2005
    332
    I think you can manage that using the parameters starting at 1300. Look for stroke check in you parameter manual, that I believe they can do what you want (inhibit a movement to a certain place programmatically)
    Oct 2007
    11
    Thank you fomaz for the response, but I think I've failed to make myself clear. I'm trying to inhibit the use of the origin soft key to zero out the absolute position. I'm fine with being able to zero out the relative screen, just not the absolute. I'm wondering if this is even possible on the 15b.
    Dave
  1. Absolute position changing...
    By Tancuda in forum Fanuc
    Last Post: 04-07-2021, 03:15 PM
  2. Replies: 2
    Last Post: 02-24-2012, 09:56 PM
  3. Absolute position getting reset
    By L. Sakthivel in forum Fanuc
    Last Post: 03-06-2011, 06:54 AM
  4. Absolute position PROBLEM
    By Darkos in forum Fanuc
    Last Post: 10-18-2006, 09:26 PM
  5. found a xyz origin position
    By mcfelix in forum Uncategorised MetalWorking Machines
    Last Post: 04-04-2006, 08:01 PM
