Well for the past year I've been dealing with a 5x10 router made in china and sold by a US based company. I thought by doing so I would get support from company. Not so I took delivery of machine and that was it. I had problems with power supply blowing up. I called got one sent and it too was DOA. So I got one on my own. Machine ran but then the xml file was garbage. So I tuned only to fine out I had to go thru machine to tighten up every nut and bolt because it was all loose. Now I'm tuned and can't seem to get machine to make any quality parts. X and Y are rack and pinion and z axis is ball screw. From what I see my z axis repeats perfectly. Its only the racks. I've done everything I can imagine but to this day a simple profiled circle is an issue. I'm .015 to .045 of when measuring the diameter. Manufacture states +-.002. Can anyone help shed some light? Or are rack and pinion setups not able to hold or repeat.
Thank you,
