I recently moved a BP Boss 6 and now the spindle motor will not start. After checking the usual suspects, I opened the head control panel and noticed that the red wire from the Spindle Enable push button switch to the Spindle Start switch had popped off (on the Spindle Start switch end). I don't have a schematic of how the Spindle Enable switch is wired, so I thought I'd ask before trying to trace out all the wiring to see if I can figure out what pin the red wire connects to. I'd appreciate any help -- what pin it goes to on the Spindle Start switch, a schematic, explanation of where Spindle Enable ties in, or a photo of the control panel backside. Thank you.
