586,110 active members*
3,162 visitors online*
    Feb 2006
    52
    breakout boards
    Hi I have started getting things together for my mill conversion and would like some input on breakout boards. I will be running geckos, 640oz bipolar motors
    and mach2 software. I don't see much out there on the pro's and con's of the different boards they all seem to offer standard items, charge pump, relays etc..
    what i dont know is what effect do any of these boards have on control, speed,etc.. I seem to like the pmdx boards but don't know what to expect between the basic 120, 122 and the 131. I also have looked at the campbell
    and hobbycnc.
    any info to help me make my final choice is appreciated
    thanks gads :cheers:
    Pretty much all the breakout boards will do the same basic things. Which is best for you depends on what features you need. How many inputs, relays, charge pump, ....
    If you plan on haveing a control panel with a lot of switches, then you may need a lot of inputs, which might call for a second board.
    The PMDX 131 is also a "motherboard" to mount the Gecko's to.
    Figure out what you'll need for your particular setup. amd find the board that will work best for your setup. You might also want to look at www.cnc4pc.com
    PS. Skip Mach2, and start with Mach3
    166
    I got one from this site. http://www.candcnc.com/ Looks to be a good one. Still have to install it.
    Bret
