586,626 active members*
2,335 visitors online*
Thread: CNC90
Results 1 to 7 of 7
    Mar 2013
    6
    CNC90
    Hello.
    In the forum i have read about problems with cnc90 and v alberti (busellato).
    http://www.cnczone.com/forums/g-code...g_cnc90_-.html
    In these link there is a user of forum that seem to have found out how to upload g-code directly to cnc90. I use ugs -. nx7 ahd have a post-processor, but i need help, beacuse cnc90 does not find programs i post-proces.
    Can anybody help me finde hidden menu, or soluttion, using nx.
    Thank you for help.
    Regards Andi
    Oct 2012
    84
    Is the post set up to output the correct file type? I don't know cnc90 but does it require a certain file type and won't see any others?
    Mar 2013
    6
    The post processor is ok, beacuse the machine reads normal g code, problem is, that v alberti has some strange directory structure. one is srg, other is something else. In srg the code is normal, but the one in other directorys in not the same. I will give an example, when i can.
    Oct 2012
    84
    What I meant was the file suffix. Like .ptp, .eia, etc. The other could be a cls or clsf file?
    Mar 2013
    6
    the files are without suffix.
    dirictorys go like cnc90/mod1/sorg/dgt
    cnc90.../srg
    cnc90.../tab
    cnc90.../ven
    and the files are
    for example: in srg/00/L
    inside is
    G71X500Y100Z100T00N4L1
    G150(LIPAR DOO)
    G81G90G54P5T0101S2500X=l Y0Z0
    M2
    and the same tab/00/L
    inside is
     LIPAR DOO 11/08/11 M úC ČB ČB  S S úC Ä ˙˙
    Oct 2012
    84
    Have you used the software before so you know it will find and use a file without any suffix? That is the only thing I can think of.
    Nov 2010
    Hallo andi
    I have a alberti ptp400 and i need a postprocessor.
    I can see your have made one in nx7 can your help me to make one in nx 7 for my ptp 400?
    Regards Bo
  1. Uploading to CNC90 - How?
    By Chris Booth in forum Controller & Computer Solutions
    Last Post: 01-11-2023, 05:40 PM
  2. cnc90 to modern one
    By eng_semsem1980 in forum Xylotex
    Last Post: 07-18-2012, 09:54 PM
  3. cnc90
    By eng_semsem1980 in forum Uncategorised CAM Discussion
    Last Post: 07-16-2007, 07:59 AM
