586,103 active members*
3,349 visitors online*
Results 1 to 9 of 9
    Nov 2007
    250
    Floating Torch Head
    My machine has changed over the years as I live and learn about the process. I've been using a Rutex "automatic" THC with proximity sensors to find the metal for the past few years, and now I want to go up on the ladder a few steps with a full featured THC. CandCNC's unit will be then one I use.
    So many use the floating head method but there really isn't much talk about the way to build one. I built a floating head of a different design. I was trying to keep the torch close to the gantry and not hang it way out in front like a few designs. And, incorporate a breakaway mount too.
    So here are a few photos of my stuff...
    Thanks for looking. AJ
    Nov 2007
    250
    Here the rest of the photos....
    Nov 2007
    250
    Last two....
    Jun 2004
    6618
    Looking good. Not sure why you needed all the switches. Mine only uses one. My Z does home on the plate though. I have a floating spindle along side my torch too. I had intended to install an air scribe on mine, but the die grinder I use works so well, that I won't be complicating matters with an air scribe.
    I did a lot of research too when I was trying to design mine. There is fairly little information, but I finally pried out enough info from nooks and crannies on the net so that I could fill in the blanks.
    Mine is farther away from the gantry as well. I wound up using a Z axis from Ebay. It all does work well though.
    I will be designing a breakaway very soon.
    I have the rare earth magnets already.
    Is your torch going to be swivel mounted?
    Sorry, didn't catch the last two pics.
    So you can miter and gouge with that setup? Nice.
    Lee
    Nov 2007
    250
    Two switches on the right are just limit switches to limit the travel of the ball screw and bellows. I only want to streatch the bellows just so far for them to live. Programming mistakes are easy so they will help save my pieces and parts from damage. Only so much money to go around...
    The swivel mount is something I was using on my older design so I put it on here. It's mainly to square up the torch and located the torch tip at the majic depth to get full movement from my ball screw.
    There are two 40lb pull magnets that hold the torch plate in place along with two locating pins...
    thanks, AJ
    Nov 2012
    64
    You have done a fine conversion there AJ, a great set of pictures there as well.
    Nov 2009
    4415
    I think LW was referring to the fact you could have used just one switch and 2 vanes.
    A lazy man does it twice.
    Jun 2004
    6618
    I didn't realize he was using Servo's when I said that. You always want all switches on a servo based machine.
    I actually plunged my stepper based plasma into a hole in the plate yesterday by accident. No problems. The stepper just stalled. A servo won't be as forgiving with a knucklehead move like that.
    Lee
    Nov 2007
    250
    If there is a mistake to be made, I've done it that's for sure and still have some around the corner I'm sure. If a guy is going to work, he's going to screw up sooner or later....
    With the plasma process, we need to keep our guard up all the time.
    AJ
  1. Floating torch head travel?
    By stealthshooter in forum Waterjet General Topics
    Last Post: 02-01-2013, 10:44 PM
  2. mach3 floating head torch crashing when homing
    By ozon in forum Canadian Club House
    Last Post: 10-09-2012, 08:22 PM
  3. Floating Torch Head
    By ajclay in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 06-21-2012, 04:25 AM
  4. Mach 3 Floating Torch Problem
    By chloeedad in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 09-04-2011, 11:21 PM
  5. Torch touch off / floating torch
    By Ubatoid in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 01-07-2011, 06:38 AM
