Hello Forum,
Note; I posted this under Mastercam forum also, because I am not sure where my problem lies.
I have a problem importing a stock (.stl) into Mastercam X4 created by Solidworks 2012 X64. The stock imports above the parasolid model. The coordinate systems, both created in Solidworks dont even line up. The orientation is correct, but thats all. I did not have this problem using Solidworks 2010 x32. Anybody else experience this or have any ideas?
I just tried an experiment. I loaded older Solidworks 2010 models with.stl stocks into Mastercam X4 and the coordinate systems worked fine. Stock matched model. I loaded the same two files into Solidworks 2012 X64, and loaded them into Mastercam X4. Stock floats above model. What is going on here?
Thank you,
Wayja
