Hi All,
I'm trying to troubleshoot a possible blockage in the flood coolant system (cutting fluid) on a LB15II.
I've checked the pump and it seems to be working fine (tank is full). I'm guessing if something was sucked through the pump it would most likely get lodged inside the turret where the flow is forced into the small diameter ports. It happened midway through a job, the coolant started dribbling out of the nozzles - same for every tool.
On the face of the turret, I've removed the top plate showing the tool numbers, and also the next plate that carries the 2 O-rings. I now have access to the plate with the coolant ports but I'm having trouble removing it. I've removed the 6 cap screws and the plate will rotate by hand but will not slide off.
If anyone is familiar with disassembling these parts please let me know. Any information would be much appreciated.
Brad
