586,105 active members*
3,297 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > OSP-E100M control info
    Sep 2009
    25
    Question OSP-E100M control info
    Hi. I need information on the OSP-E100M control. Does it support DNC and what type? does it have a hard drive? USB or ethernet ports, etc.
    A brochure or specs sheet would be great!
    Thanks!
    mfugs
    Feb 2009
    6028
    Don't think the E100 did. DNC was an option. None of our E100's have USB or ethernet. U100's might.
    Sep 2009
    25
    Thanks for your input, underthetire. Do you have a PDF you can upload with the specs for any of your E100's?
    Thanks!
    Feb 2009
    6028
    Nothing that would help you. Pretty old control now.
    And be aware- Okuma is REALLY expensive on control parts, and you have very little choice but to get them from the Okuma dealer. They also do a very poor job at supplying older parts. Ask anyone that had to replace a VAC-A drive from the 90's and got a $15K bill for the retrofit. I can still get a repaired Fanuc drive for a early 80's machine for a couple grand.
    Sep 2009
    25
    Im a bit confused. The E100 control is the last control before the think control, and it is supposed to be very similar to the think.
  1. Need connector info on ml22 with a C6 control
    By clytle374 in forum Milltronics
    Last Post: 03-29-2012, 04:03 AM
  2. Fanuc 0i MATE control info reqd
    By dawilbers in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-25-2010, 06:55 PM
  3. Need s/w and info on EmcoTurn CNC lathe with a Fanuc OT control
    By richarddoucet in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-28-2008, 03:55 AM
  4. Step and direction info on M control
    By colin1544 in forum Centroid CNC Control Products
    Last Post: 05-31-2006, 02:00 PM
