586,396 active members*
3,090 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Difference between 320 and 340?
Results 1 to 6 of 6
    Dec 2005
    67
    What is the difference between the Gecko 320 vs 340??
    The only thing I could find was the "step pulse multiplier". Does this essentially magnify or multiply the steps coming from the PC software and send that on to the motor, thereby speeding things up?
    I do not have a high or even medium speed requirement, so if the above is true, then I should probably stick to the 320??
    This is what I'm thinking, but let me know if I'm wrong please.
    Andy
    Andy M.
    Basically your correct. If your PC can output steps fast enough to use the G320, then you don't need the G340. This can be somewhat dependant on your encoder count.
    Jun 2003
    114
    Quote Originally Posted by ger21
    How can i find out if my pc can output steps fast enough to use the G320?
    You need to know how many steps/second you need, first. Then, if you're using mach3, it can output 25,35, or 45,000 steps per second. You'll need at least a 2 Ghz PC to use the faster speeds.
    Jun 2003
    114
    Since my slowest pc i have is a PIV 2.26Ghz i guess i can go with the 320´s and take the full advantage of using mach3 at 45,000 steps...correct?
    Regards,
    Hector
    All PC's run Mach3 differently. You really need to make sure it runs OK at 45Khz. Art usually recommends running at 25Khz, unless you really need to run faster.
