This seems like a promising start on a router, although whether it will be heavy-duty enough to mill metals. Not sure about those motors, though - most steppers I've seen run on DC. If you can figure out how to get those drives to accept step/direction signals, then this would probably work with hobby-style control software like Mach3 or Linux CNC. Otherwise sell it for what you can get and buy something you know will work. See if you can mount one of those stages on top of the other (that table looks promising to build on top of), and check the assembly for rigidity. That would give you X and Y, but you'd still need something to mount your Z axis and spindle on that would hang over the table- you might start scrounging for a big arbor press or a clapped-out mill casting.
Andrew Werby
ComputerSculpture.com ? Home Page for Discount Hardware & Software
