586,069 active members*
3,826 visitors online*
Results 1 to 7 of 7
    Apr 2012
    HAAS TL-2 Chuck
    I am a new machinist who recently had my first crash, i don't know how else to put it but the part came out of the chuck and damaged part of the chuck. This was last friday 5/3/2013, and i had looked at the chuck, and jaws and found no series damage, a little bit of the ss i was cutting got stuck to a jaw, but it was still on center. Then today 5/7/2013 the chuck had release a second part and did some more damage. I am starting to think that the jaws or the scroll system inside the chuck might be bad. How would i know? Also where would a good place to buy jaws for a ten inch chuck?
    Mar 2010
    1852
    More info is needed.
    I see you are cutting Stainless, but what size parts, how far does it stick out, but what depth of cut, what RPM (too high=will open jaws)(too low would cause the part to be pulled from the jaws), steel jaws or aluminum soft jaws, how deep is the part into the jaws, what tool.
    Steel jaws and soft jaws are both available on eBay and many tooling dealers.
    Feb 2010
    1184
    Quote Originally Posted by Machineit View Post
    All excellent points
    Quote Originally Posted by Cody.Chandler View Post
    Cody, there can be many factors that cause a part to come out of the chuck jaws as Machineit pointed out. You mentioned that you are a "new machinist"; how new, any past experience with a lathe.
    Please describe in DETAIL how you are holding your part. If using machinable soft jaws, provide a DETAILED description of how you are machining them and how you set your diameter.
    Are you getting the hint, details are important here since you are the only one who can see your setup.
    Mar 2010
    1852
    Why is it that they seem never to get back to us with the details and solve the problem!?!?!?!?!?
    Mike
    Apr 2006
    3206
    Mike
    Because he's looking for a new job maybe??
    Mar 2010
    1852
    Quote Originally Posted by fizzissist View Post
    May 2013
    What brand is your chuck? I ask you this because my new TL-2 came with a 10" 3-jaw Atlas chuck, it's jaws where 0.003" off centre (almost 2 months trying to figure out the problem), tech support came, checked the spindle, re-aligned the chuck and the 0.003" remained, so they changed it for a new one (also Atlas) and it had the EXACT same defect, now I'm waiting for the replacement which they say is from a different manufacturer, the tech guy told me there's been QC problems with the Atlas chucks.
  1. Replies: 0
    Last Post: 04-30-2013, 03:59 PM
  2. Haas Srt Chuck?
    By K_Labs in forum Haas Mills
    Last Post: 02-22-2012, 07:56 PM
  3. Anyone us the Haas 5c collet chuck?
    By shawncnelson in forum Haas Lathes
    Last Post: 09-17-2009, 08:52 PM
  4. HAAS HL-4 chuck help to remove
    By joanpim in forum Haas Lathes
    Last Post: 05-20-2009, 09:34 PM
  5. Haas Control and Vacuum Chuck
    By big_mak in forum Haas Mills
    Last Post: 10-01-2007, 07:25 PM
