586,103 active members*
3,915 visitors online*
IndustryArena Forum > Community Club House > Problems with Centroid Equiped Bridgeport when homing
    Mar 2006
    14
    Just purchased a Bridgeport series II with a M400 control on it. The guy I bought it from put the control on it 1997 with all new motors and control from centroid. He made 4 prototype parts and hadn't used it in 12 years. The control and motors are basically new. I got the machine back to the shop and hooked up to find that 3 of the 4 axis were backwards so I changed that via the control and switched the limits accordingly so they all travel and limit in the correct orientation. The problem I am having is that when I hit cycle start to home the machine it will home the Z then the X, but when it gets to the Y axis it moves slowly to the Y+ limit and when it hits it the machine throws a code saying 'Y+ Limit', and the next line is 'Y axis full motor power no motion'. I can't use the jog buttons to back away from the limit and have to turn the pulley by hand until the control reads 'y limit cleared'. Then the Y axis will work from the jog buttons. I can't get past that point and don't know where to go from there. Any help would be greatly appreciated.
    Best regards,
    Dennis
    Mar 2006
    14
    Got it figured out. Turned out to be 2 bad encoders and the limit switches on the Y axis were wired backwards. It's up and running now! Time to start makin some chips!
  1. Problems with Centroid M400
    By glbreil in forum Centroid CNC Control Products
    Last Post: 12-12-2023, 05:46 PM
  2. Centroid Problems
    By Engine Tech in forum Centroid CNC Control Products
    Last Post: 04-28-2020, 07:14 PM
  3. Centroid & MPG Problems
    By Marty_Escarcega in forum Centroid CNC Control Products
    Last Post: 10-15-2011, 03:22 PM
  4. Offline Centroid Intercon Problems
    By jime in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-05-2006, 11:20 PM
  5. Centroid M-400 Problems
    By Acinch in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-04-2006, 10:03 PM
