586,061 active members*
4,548 visitors online*
    Jun 2009
    6
    Question Breakout board wiring help!
    I bought this breakout board and I'm confused at the USB power/voltage. It has a 5v input from the USB cord to power something as well as a 12v to 24v terminal input? Do I need to use them both or just one? The manual does not clearly say. Also will the power carry through the wires into my stepper controllers? Cause I will be running the stepper drivers at 36V, and I don't want anything to be mixed up.
    Image: http://i.ebayimg.com/t/US-seller-Upg...kI7w~~60_3.JPG
    Manual: https://skydrive.live.com/?cid=88fb6...PSeNu5hZHOhv5k
    Jun 2011
    695
    The 12-24 volt is input for the 0-10 volt out. You won't need it for board to operate. You can use it to control a VFD drive if you have the need.
    Hurco KMB1 Build
    Wholesale Tool 3in1 conversion
    C-Constant
    N-Nonworking
    C-Contraption
  1. 5 axis breakout board wiring PLease :'(
    By isowe in forum Gecko Drives
    Last Post: 08-18-2017, 08:13 PM
  2. Motors, Drivers & Breakout Board Wiring
    By OnezerO in forum Stepper Motors / Drives
    Last Post: 07-24-2014, 11:21 PM
  3. CNC4PC.com C11 Breakout Board wiring.
    By thunderdork in forum CNC Machine Related Electronics
    Last Post: 10-29-2013, 06:53 PM
  4. wiring Chinese Breakout board
    By silyavski in forum CNC Machine Related Electronics
    Last Post: 07-29-2011, 02:22 PM
  5. Wiring Breakout Board Questions
    By Dingo745 in forum Xylotex
    Last Post: 03-31-2008, 08:47 PM
