Originally Posted by
Stuff-Builder
Something is very wrong with it right now. I just did some testing and I was getting power out of a relay that isn't even hooked up.
Keep in mind that a solid state relay will measure a voltage out with no load connected to it when using a high impedance meter like a modern digital voltmeter, this is due to the inherent leakage of the SSR and the high impedance of the meter. It's is just that this leakage will not support any kind of normal load so you do not see it normally.
Al.
Albert E.
