586,119 active members*
3,507 visitors online*
IndustryArena Forum > CAD Software > Rhino 3D > Create a relief in a surface.
    May 2013
    4
    Hi guys,
    Been trying for days now to create a canopy recess in my fuse. It needs to be a solid when complete so I can do a Boolean difference for mold making...
    The canopy would be about .015 thick.
    Jul 2004
    42
    You views are labeled wrong. The way I did my canopy was to draw a curve on the right view and project to the C plane. Extrude the curve to pass fully thru the fuselage. Use the split command to split the canopy from the fuse. I hope the attachments will help you see what I am saying.
    Joe
    Dec 2008
    4548
    Not sure of the exact outcome you want. If you look at your picture from the front view, draw a curve like that red shape and extrude a surface from it across the fuse. Then you can use the boolean split or something else to get an object to work with.
  1. Fifty ways to create a relief - Part five
    By cncadmin in forum EnRoute
    Last Post: 10-24-2012, 06:40 AM
  2. Lesson how to create relief from photo
    By Melkiades in forum ArtCam Pro
    Last Post: 04-26-2012, 09:18 AM
  3. How to create fillets on this surface
    By gorby in forum Mastercam
    Last Post: 03-19-2012, 06:46 PM
  4. How to create surface
    Last Post: 11-22-2010, 08:09 AM
  5. How to create 3D surface
    By kiemkhach in forum Mastercam
    Last Post: 07-04-2008, 12:48 PM
